Carb not responding to adjusters...
Discussion in 'The Workshop' started by dangur, May 5, 2012.
  1. dangur
    dangur New Member
    The engine idle is too low, its always bogging down no matter what I do with the carb.
    What could be the problem?
    Carb is original (17.5?) on typhoon 2006
    Thanks.
  2. IceIceBaby!
    IceIceBaby! yz125/ TTR250/ sold gilera ice
    TTR250
    what size main jet you got?.. and whats been done to the bike?
  3. dangur
    dangur New Member
    Carb is original so I guess the main jet is 70? The bike has 70 sport pro mk2 kit with pro replica exhaust for now...
    The problem is it did the same thing before the upgrades.
  4. IceIceBaby!
    TTR250
    have you not changed the jet since upgrading it?..
  5. dangur
    dangur New Member
    ^No, what jet size would you recommend?
  6. IceIceBaby!
    TTR250
    erm well put it this way.. i had a 56 jet in mine when the bike was standard.. i put a 60s kit in mine and put a stage 6 race pipe on and i went upto a 70 jet.. its a little to big tho.. so you need to find out what has been done to the bike and what the orignal jet size is and tell me..
  7. dangur
    dangur New Member
    Jet is 65, the bike have stage6 70cc kit with stage6 race pipe.
  8. IceIceBaby!
    TTR250
    erm personally i would put a slightly bigger jet in but that does sound about right.. im really not to sure
  9. dangur
    dangur New Member
    Not responding...Any ideas what to do? :/
  10. IceIceBaby!
    TTR250
    tbh i really am not sure with that, never had that problem with mine :/ im not sure what to suggest..
  11. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    have you cleaned the carb out. best bet would be too take the float bowl apart remove and clean the jets and clean the carb out the best ou can. I use wd40 sprayed through all the holes etc to clean it out
    i had a issue with my runner bogging and cutting out and only wanting to start on full throtle. Turned out to be a blocked pilot jet
  12. Archibald33
    Archibald33 Member
    You need to find out what has been done to the bike and what the orignal jet size is
  13. IceIceBaby!
    TTR250
    yeah you wana make sure the carb is clean.. tbh i wouldnt use wd40 coz its not great with fuel and you may have a fuel starvation problem for a few days..
  14. creamsodauk
    Runner 125 SP
    fuel starvation for a few days? you spray it throughout the carb and then wipe it down, the amount left will be pretty much nothing. Pop the carb together and kick it over a few times til it starts.
    I did squeeze my fuel pipe to the carb and kick it a few times to prime the pipe again but thats just being ott
  15. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Mine was doing this, it was the idle jet. Don't forget that a sport pro kit and an exhaust is still gonna need more fuel even at idle. Go up a size or two on the idle jet, this will free up some adjustment with the air fuel screw.
    When that it set up right, you may find that the idle screw actually makes a difference
  16. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    Allways use carb and choke cleaner for your carbs and blow through with an airline. WD40 contains parrafin and it can damage rubber seals.
  17. creamsodauk
    Runner 125 SP
    agree with the above not ideal. but we use what we have to hand haha
    bank of dad likes this.
  18. dangur
    dangur New Member
    I have cleaned it with carb cleaning spray and still nothing changed, I think something is fucked with the carb so I ordered new one.
  19. dangur
    dangur New Member
    Ok guys the new carb is here, it's motoforce 17.5 with 65 main jet. Should I upjet it to 70?
    The typhoon running 70cc sport pro mk2 kit with pro replica pipe and polini variator.
    Thanks.
  20. IceIceBaby!
    TTR250
    i would use a 70 but try it and see how it runs then check the spark plug and see what colour it is ( if its light then its runing lean and needs up jetting )
