carb and wheelie...
Discussion in 'The Workshop' started by romeopat, Mar 15, 2011.
  1. romeopat
    romeopat New Member
    just wanting some advice
    my setup is
    Malagut f15 2006 ac
    stage 6 sport pro 70cc kit
    4.5g rollers ( standard variator )
    yellow polini clutch springs ( got a set with chrome yellow and green )
    polini 3.8mm torque spring
    malossi delta replica clutch
    upjetted carb
    malossi air filter
    basically i was wondering if someone could point me in the right direction as i am wanting a bit of lift on the bike ( for wheelies lol )
    what would i need to change?
    also my friend has a dellorto 17.5mm carb will this improve my bike? or what will it do...
  2. lshigham
    lshigham Member
    Have you got the stock exhaust on it?
  3. romeopat
    romeopat New Member
    sorry forgot to mention got leo vince ZX
  4. lshigham
    lshigham Member
    I would go out and buy a S6 MKII clutch. Put the red springs in, and it'll certainly have a ''bite'' when it pulls off.
  5. tErr0
    Stronger clutch springs will make it bite at higher rpms meaning more power. Horrible for actually riding about though because you end up jerking around all over the place and having to rev the shit out of it to pull off.
    I think what it really comes down to is your technique.
  6. roxi-46
    roxi-46 Member
    just wondering if you put a race clutch in with stiffer springs (on a standard barrel) how much difference would it make?
  7. romeopat
    romeopat New Member
    whats the benefits of a dellorto 17.5 carb?
  8. tErr0
    Just going to be killing your clutch bell and everything else.
    As for the carb a bigger carb is always a good idea. 17.5 isn't very big however.
  9. romeopat
    romeopat New Member
    terro what would you suggest i do?
  10. roxi-46
    roxi-46 Member
    no point in having a race clutch with a 50 then?
  11. romeopat
    romeopat New Member
    terro what will happen if i keep running it as it is now?
    what will i benefit from a bigger carb
