carb adjustment
Discussion in 'The Workshop' started by h.hubbyy, May 3, 2012.
  1. h.hubbyy
    h.hubbyy Member
    JOG R
    how many turns should i turn the screws on my 17.5 carb running on a 70cc? could this affect the speed? thanks
  2. CA Zip tuning
    CA Zip tuning Member
    Are you talking about the idle screw ?
  3. CA Zip tuning
  4. h.hubbyy
    h.hubbyy Member
    JOG R
    both haha , it cuts out wen i let off the revs
  5. CA Zip tuning
    Try adjusting the idle screw as shown in this video, also what size main jet do u have in ?
  6. h.hubbyy
    h.hubbyy Member
    JOG R
    which screw is which? there are 2
  7. oliwest
    oliwest Member
    aerox road legal pit
    The idle screw is the one you can turn with your fingers with a spring and the mixture screw is the flat head screw
  8. h.hubbyy
    h.hubbyy Member
    JOG R
    okok which one should i touch? could the mixture screw be affecting my speed if its not set right? and how many turns should they both be on roughtly? thanks
  9. CA Zip tuning
    try the mixture screw first
  10. h.hubbyy
    h.hubbyy Member
    JOG R
    ok thanks , will do it tomoz as its too dark , do you know how many turns it should be open though :/ ?
  11. CA Zip tuning
    1 1/2 turns mate
  12. h.hubbyy
    h.hubbyy Member
    JOG R
    ok thanks , and the idle one shall i just try till it sounds right? like do the mixture one as tight as i can then open it 1 1/2 turns , then the idle one i do all the way up then open it till it sounds right? thanks
  13. CA Zip tuning
    np, switch your bike on and just adjust it from there rev it ocassionally so u can here when its changing, when it sounds about right then its tuned like on the video i showed u and for the idle screw get a flat head screw driver i think it is or a star one not sure and do the same thing as the man did on the video ;)
  14. h.hubbyy
    h.hubbyy Member
    JOG R
    thanks m8 will let u know how it goes tomoz
  15. CA Zip tuning
    Ok inbox me pal
  16. h.hubbyy
    h.hubbyy Member
    JOG R
    it was open 4 turns :confused: ? i have opened it 1 1/2 and no difference , and the idle screw doesnt change anything and it still cuts out :confused: ?? any more ideas?
  17. h.hubbyy
    h.hubbyy Member
    JOG R
    the needle is on the highest notch btw
