cant get my variator off
Discussion in 'The Workshop' started by ryhan_pea, Jul 1, 2007.
  1. ryhan_pea
    ryhan_pea New Member
    ive got an lx50 and i cant seem to undo the variator. ive been using my impact driver but it just isnt coming off. is it mandatory to have the variator tool cos i thought i read somewhere thet you need either not both?
    does it have a reverse thread so it doesnt loosen itself??
    i'm pretty sure it is a normal thread tho?
    thanks
  2. wobbly_trials
    i'm not aware that it has a reverse thread, usually an impact gun will undo it streight away. air powered ones are the best.
  3. JakeSP
    JakeSP New Member
    Again, Not sure if its reverse thread (should be able to see if you look close enough)
    I knocked up a holder in 15 mins, Heavy duty (i never use the impact gun on my own scoots in fear of bending/twisting/snapping the crank)
  4. capri dave
    capri dave Active Member
    sometimes it takes 3 or 4 attempts with the impact gun to loosen the
    variator nut, if the nut has been tightened up very tight!!
    I always use an impact gun myself...and havent had any crank problems!!
  5. ryhan_pea
    ok its all sorted now, made aholder ina bout 15mins aswell out of an alloy or something as i only had really think steel that would take ages to cut.
    nut came off easy, im so clear on how these things work now so simple yet so effective.
    i removed the washer now but i do need the bigger jet it just doesnt get enough fuel to pull through the gearing
  6. moansss
    moansss Member
    i got the same problem could anyone come an do it for me??
  7. haugh
    haugh New Member
    How many more times you gunna ask?
  8. moansss
    moansss Member
    untill i do it or sumone helps me do it ;)
  9. haugh
    haugh New Member
    Uhm...
    then you will be more than likely banned for nagging lol ;)
  10. haugh
    haugh New Member
    You need to upjet when you remove the washer? :wtf:
  11. The General
    The General Member
    u dont need to upjet just from removing the washer lol
  12. tinribs
    tinribs New Member
    i thought you did with the lx as the jet is only a .53 standard
    EDIT - he's got a derestricted pipe on it too....
  13. xenovia
    xenovia New Member
    you need to upjet about 4-5% with the pipe, and go from there. Probably best to get a bunch of jets and see which one suits your scoot the best by riding and checking the plug colour.
