can you buy replacment rings or piston and rings for 70 kits
Discussion in 'The Workshop' started by chris14, Sep 3, 2008.
  1. chris14
    chris14 New Member
    might be buying a 70cc hebo manston replica kit,
    just wondering weather you can buy replacing piston and rings or just rings on there own for this kit if not would any 70cc piston fit etc might sound like a dumb question but not sure
  2. Dec
    Dec Active Member
    nothing ugm
    yea find the 70 kit on scooter attack then look at related products it should have all the individual parts.
    ive always wonderd weather you could use a single ring piston in something that had a 2 ring, for eg. an evo piston in a polini sport? what would be the effects?
  3. chris14
    chris14 New Member
    thats what i was wondering
    surely they must all be the same size as there 70cc
    any body know weather you can use differnt pistons etc
  4. chris14
    chris14 New Member
    well app a piston for the hebo kit is 47.6mm
    so i spose if u find another piston of the same size it would work
  5. RY4N172
    RY4N172 New Member
    Where did you buy your kit from ?
    if s-a or s-c if you scroll down on the page
    there will be related bits to that kit e.g piston
    gaskets , rings etc
  6. one7twoboi
    one7twoboi New Member
    No dont use different brand pistons in different cylinders. Not a good idea, trust me lol either buy a piston kit, or find a yamaha or makita dealer who do replacement pistons an ask them for the size u want
  7. MiNoR cOnFuSiOn
    aslong as the piston is the same size and for the same fitment you can prittymuch use any piston in any kit.. as stated it needs to be the same diameter (verry close tollerance on this) some kits the piston crown and port latyout is slightly higher altho this is rare so a carefull squish test is always best when experimenting. single ring in an mhr rep means you can open the transfers out and prittymuch lay an evo 2 port map over the top ;)
  8. Dec
    Dec Active Member
    nothing ugm
    beautiful. :p
    what would it perform like then just bolt on?
