Can someone help me pls?
Discussion in 'Bike Chat' started by Niks Nikandrovs, Jan 23, 2020.
  1. Niks Nikandrovs
    Niks Nikandrovs New Member
    I'm in need of help, I have a peugeot speedfight 2 50cc LC 2001 and I cannot get spark, I've changed the following:
    Stater
    Cdi
    Coilpack
    Sparkplug
    Whole new wiring loom
    If someone has any ideas can you please put them below or something, much appreciated.
  2. Mark Emerson Trentham
    Ignition switch.?.
  3. Niks Nikandrovs
    The starter motor works when I turn it on.
  4. Stevep
    Is all the above new parts, or used?
  5. Niks Nikandrovs
    Used but came off fully working peds
  6. scubabiker
    Check the connection to the cdi.
  7. Niks Nikandrovs
    Yes, I have, I've tested all ports and gave them a little clean
  8. scubabiker
    Battery?
  9. Niks Nikandrovs
    The battery is connected and gives out electric
  10. scubabiker
    How many volts?
  11. scubabiker
    Try a totally new spark plug, not a used one. Sometimes it's as simple as that
  12. Niks Nikandrovs
    Ah, okay thank you, I'm off to get one tonight then, I'll respond and see if it helped or not, cheers
    scubabiker likes this.
  13. scubabiker
    Start with the cheapest thing first.
    Top tip from a mechanic there.
  14. scubabiker
    Also fun fact, if you use a 4 stroke Honda cdi, your Peugeot will start and run backwards...
    Niks Nikandrovs likes this.
  15. Niks Nikandrovs
    Just changed spark plug, but still no spark. I have no absolute idea what Could it be
  16. Mark Emerson Trentham
    Wiring break.?.
  17. Niks Nikandrovs
    Inspected wires, no problem with those
  18. scubabiker
    Are you getting power to the cdi?
  19. Niks Nikandrovs
    Yes, I've tested the wires there too... .
  20. Stevep
    Check the air gap between the pickup and the flywheel, should be about 1mm.
    Also make sure both surfaces are clean (the round pip on the pickup and the raised section on the flywheel)
    As the raised piece of the flywheel passes over the pickup it sends a pulse along the wire to the cdi to tell it to send a signal to the coil which then creates the spark.
