Hi, I have an Aprilia RS 125, and the bloke I bought it off said he had just been using cheap 2t oil. I know that the rs needs good oil so I was wondering.. there is still cheap oil in the bike, would I be able to put a good quality semi synthetic or synthetic 2t oil in with it? Thanks, Grant.
Re: Can cheap 2t oil be mixed with semi synthetic or synthet we had an identical question to this some time ago...just a different scooter to cut a long story short...yes its ok to mix the 2 oils :good:
Re: Can cheap 2t oil be mixed with semi synthetic or synthet USULY it's ok to mix the two, i have actually had one type emulsify with another before now. i would reccomend draiing the tank then putting fresh in if you know how or at least running very low before you top up with fresh. its unlikely it will cause a problem mixing the two though.
