Broke down this morning!
Discussion in 'The Workshop' started by capri dave, Nov 27, 2008.
  1. capri dave
    capri dave Active Member
    I've had a bit of an eventful morning, I was riding to work as normal, and my Runner
    broke down.
    I've whipped the engine out, and took off the head, and I've holed my piston. Luckily the barrel still looks in very good condition, so it should only take a new piston, rings and a gasket set. And I'll be on the road again.
  2. Jefr0-180
    Jefr0-180 Active Member
    Eeeek what caused the hole?
  3. MiNoR cOnFuSiOn
    lean partial throtle.. lift the needle a notch or two ;)
  4. capri dave
    cheers minor i thought it was caused by lean running, but didnt think about partial throttle.
    i was going to fit a bigger main, but i was thinking fuck me if its running that lean, what the hells it gonna go like with the proper jet in :w00t:
    Heres a very interesting article ive got on my computer from somewhere, i may as well share ;)
    http://www.smellofdeath.com/lloydy/pist ... _guide.htm
  5. MiNoR cOnFuSiOn
    lots of dead single ringers there LOL
    WELL handy tbh as alot of the time i still refer back to articals/old tunning books.. cant remember everything.
    so what jet you running atm dave? needle position?
  6. Mehmet
    Mehmet Active Member
    AUDI A3
    I was talking about your bike this morning to some other people about how nice it is.....i think i put the devils eyes on it :(
    loool but seroiusly i was talkin about it to my cousin about it.
    ow welll
    hope its back on road soon again and touch wood nothing goes wrong :D
  7. capri dave
    im running an 88 main jet (pre-mix)
    cant remember the needle position...been a while..
    And theres no carbon anywhere on the crown or head, in the pictures is how it was when i pulled the head off after 9 months running :w00t:
  8. capri dave
    yeahh could of been worse m8....the barrel looks in very good shape considering, no sign of scoring ;)
    must of been the 33:1 pre-mix, which could of also contributed to the lean running..
    you have to put a bigger main in for pre-mix...cause oil aint fuel if you get me :D
  9. waxhead
    waxhead Member
    detonation
    bang straight through the centre of the piston
    im suprised it wasnt destroying plugs before this
    what ignition do you have in it
    more fuel wil stop the deto as well as like minior said
    but its time for a decent inner rotor as well
  10. capri dave
    stock ignition...but i changed my Laser for a yasuni c16 nearly 2 weeks ago.
    I had nearly 9 months trouble free running with that kit and the laser, im assuming its running leaner now ive fitted the yasuni ???
  11. waxhead
    waxhead Member
    yeah it may be running leaner but its also may be running hotter if the yasuni is scavengine better up top which we know it is for sure
    you will be going to new heights in rom and the ignition curve of the stock ignition is not designed to do that and will be holding to much advance
    Fattening it up will fix the issue
    however if you decide to get a decent ignition retarding it up top will add to over rev and power
  12. MiNoR cOnFuSiOn
    or file the pickup points upwards by a mm or two, wind the clutch up and set the dile mix well and youd never notice the dip at bottom ;)
    ajustable timing is a fucking good thing to have, but the only one for true road use (no fucking about with charging battery's) is the polini an even thats not inner roter,
    if you have one with more than 10w output ill buy 10 of em LOL
  13. NJH
    NJH New Member
    unlucky mate! only saw you fly past yesterday haha
    glad its a simple fix though!
  14. waxhead
    waxhead Member
    yeah you could do that with the pickup that would work fine
    Im using a non charging system
    I was going to hook up my 10 watt system but couldnt be botherd
    I have a solar panel under the seat when i stop i just pull that out and sit it on top of the seat and it charges the battery
    Of course on the gold coast we have lots of sun
    im not sure how it would work in england
  15. MiNoR cOnFuSiOn
    well, solar panneld peds arnt about just yet here in rainy old england! LOL
    need lights, the wether here is seriously shit LOL
  16. waxhead
    waxhead Member
    fair enough
    i dont have the lights on my scoot
    i just have a switch to turn them off and on
    but if i want to ride at night
    I just ride my car
    hahaha
    it warm enough here that i ride in board shorts and a tee shirt all the time
  17. MiNoR cOnFuSiOn
    *awaits story and pics of dirty road rash*
    LOLOL
  18. capri dave
    heres a pic of the piston and barrel, i was quite pleased with the overall condition, no scores at all....well apart from a big hole that is :pimp:
  19. MiNoR cOnFuSiOn
    your loosing the lip over the exhaust side of the piston, would have broken down to the ring in the end.. lift the needle to the highest position (make it struggle and throttle mad to get any revs basicly) then work down.. vary the speed but do continuous throttle position checks.. as in 1/4 throttle, check the tone, same at half and 3/4 throttle.. then work out the needle position/diff dimentions of required needle. if your really picky about it and make lots of notes you can work out the exact needle from throttle positions and needle settings ;) (dell website for needle dimentions)
  20. capri dave
    Who would of thought an exhaust change could cause all this aggro :confused:arc:
