I took ma front brake pad off 2 see what type i needed, put it back on and now the brake dunt work the lever has too much pull help!!
it needs bleeding mate, search "bleeding brakes" on the search guide and im 100% sure it will come up somewhere how to bleed brakes if you dont know
wont need bleeding if he has only pulled pad out. pump the lever a few times probs will just be the piston that gone back.
did you undo the bleed nipple? if s then it will want belding if not just pump the leaver as it will have to push the piston back out as you will of forced it in to get teh pad back in troy
