my aerox's brake light operates correctly when the ignition is on, but as soon as the bike is started, the brake light stays on. Does anyone know whats causing this and how to fix it.. thanks, tommo.
wrong type of bulb or its in the wrong way have you had a look and tested a diff bulb? i had a old ba15s where the terminals were opposite to the usial ones
thanks for that, but just sorted it, took the bulb out and the 2 contact points were slightly corroded. I sanded the corrosion off gently and it all seems to be ok
