bought a vxr
Discussion in 'General Scooter Discussion' started by shiny red, Dec 15, 2007.
  1. shiny red
    shiny red New Member
    had to try a 4t so been and bought a vxr 180 02 reg black got it of e bay ,body needs a tidy but engine and running gear spot on ,had tyres , engine mounts, brakes and a service two weeks ago but failed mot on one fork seal ? i only paid 400 for it now that is cheap,best bit i got the no plate valued been offered £1500 wont belive it till i got the cash, any way got to get it mot d then we will c.????had a quick ride not like a 2 stoke at all. i take some pics today and post em :w00t:
  2. StEvO
    StEvO Active Member
    even it thats valued anywhere over say £700 sell it, you will still make money (after you've bought another registration and payed the fee's etc) and unless it's something majorly special its only a number plate, not really goin to make much difference to the bike is it lol
  3. shiny red
    to right they pay all the fees so its got to go :w00t:
  4. shiny red
    What do you think?
    [​IMG][​IMG]
  5. StEvO
    StEvO Active Member
    i think its got 210kit potential? :D
    but yer spot on for what you payed fella, you got a bargain.
  6. haugh
    haugh New Member
    or
    "Had your knickers down?" as gay boy would say ^^^
    :bird:
  7. MiNoR cOnFuSiOn
    honestkly dont bother with the 210.. better to run the 200barrel with diff valves/ground cam and a decent port job on the head. a barrel an cam will cost you neer on 900 quid where as a second hand 200 engine and a couple hours with a grinder will give similer if not better gaqins for naff all outlay
    with 4t's dont buy aftermarket bits.. use stock bits from a higher moddle and go from there
  8. StEvO
    StEvO Active Member
    Well haugh u did u knobhead lol
  9. MiNoR cOnFuSiOn
    bit untidy but good for the money...
  10. shiny red
    if the no plate goes for what i been quoted then it will get the treatment,i was thinking ported 200 barrel too,first thing will be malossi forks so used to the ones on shiny, can not get used the bouncy front end at all :( the power delivery is so different to the 2t steady rather than light speed ):w00t: got to get rid of the air box and standard pipe too. will be picking your brians on the engine then minor ?
  11. MiNoR cOnFuSiOn
    can do, never really done a 4t ped but plenty of cars an big bikes so quiz away...
  12. wobbly_trials
    just a quickiee, you port the head on a 4t, the barrel is just a tube basically, no ports to port.
  13. MiNoR cOnFuSiOn
    power comes from the head and the pistons.. the bottom end just has to last a long while. and ye the cylinder is exactly that, no holes. porting them is fairly easy by looking at the head.
  14. wobbly_trials
    yup, the machining involved can be difficult, try opening the valve seats and using bigger valves
    edit: is the vxr 2 or 4 valve?
  15. MiNoR cOnFuSiOn
    4v.. its lower end bikes that have the 2v and the ac engines... these are the best to do a big wc 4t conversion to..
    anyway the best bet is use slightly longer valves and grind the cam back.. wears out quicker and theres more side load on the valves but it does save you 350 for a malossi crank :confused:arc:
    can get good gains from just a 200 barrel and some decent grind work tho.
  16. shiny red
    sorry so used to two strokes,machining the head no problem 5 axis cnc mill sat at work just waiting to used ,, :w00t:
  17. MiNoR cOnFuSiOn
    noice.. i could do with one of those... using a crappy 3 axis soft mill at work :confused:
    what progs you run on it? could draw som things up for ya an make plastic proto's for ya.. obviously weigh you in just need a friendly miller with equiptment to match my needs.
    alot of it will need to be done by hand tho
  18. rossmofo
    rossmofo New Member
    gilera Ice ZX7R
    :D Well done RED , good to hear about someone getting a bargain, instead of the usual tales of people getting ripped off. And by the sound of it a Project is born. :punk:
  19. shiny red
    cheers ross :D wot you thinking then minor ;) hypermill v7 take anything really IGES,STEP,DXF,VDA etc can use a vertical EDM and wire could be interesting ?give me some exmple of wot you need :nerd:
  20. Jefr0-180
    Jefr0-180 Active Member
    Got yourself a bargain there!
    Steering looks out but that probs just needs tightening at the top as previous owner has had a fall.
    But a 4t............pffff :rofl:
