It might be dumb question but could you possibly make a bit more power when you would bore out the exhaust port and also the exhaust pipe header and use a bigger carb ? Could you flow more air and fuel through your engine (2 stroke) ? Thanks
That's exactly what porting is. Top tip from me. Start by just polishing your exhaust port and the top of the piston. Should gain a bit more power.
but would the larger id theoretically increase power ? also does the cylinder exhaust port id have to match the exhaust pipe header id ?
