boost bottle
Discussion in 'Scooter Tuning' started by benn, Jun 26, 2012.
  1. benn
    benn Member
    speedfight 120
    Okay bit of a nooby question but can anyone actully tell me what an boost bottle does, i dnt see how it can boost speed or save fuel, does it just push more air threw or fuel?
    cheers
  2. MARSH
    It's a reservoir that holds fuel/air mixture, it only work's for a split second when you crack the throttle open, a small boost in mixture. Early 2 stroke bikes used them, it affectively helps iron out a poorly set up carb. Personally i think they work, others say not. There not expensive, try one, if don't work for you sell it!
  3. Chubz
    Chubz Well-Known Member
    70cc Aerox 04'
    Basically if you own one.... place it in a bin
    and if your planning on buying one, buy some beers instead :)
  4. iNEEDaNEWped
    iNEEDaNEWped Member
    i've told you before.. they add atleast 20mph to speedys
  5. Chubz
    70cc Aerox 04'
    LOL ^
  6. Jonnymarrw00t
    Piaggio Zip 05 plate
    Rather spend the money of fuel tbh.
  7. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    Apparently they seem to work on bikes which have disc valves and any improvement on am engine with read valves is negligible.
    roxy boy likes this.
  8. WTPchiefSKP
    WTPchiefSKP Member
    cpi sm77
    i got a boost bottle and tbh its the worst thing i done. it uses more fuel and slows my acceleration and top speed down so i quickly removed it :)
  9. MARSH
    You must have fitted it wrong, they don't slow your scoot down or use more fuel.
  10. WTPchiefSKP
    WTPchiefSKP Member
    cpi sm77
    maybe so but i installed it as the instructions said so i dont know it will go back on with a bit more tuning
  11. Jonnymarrw00t
    They do nothing on small cc two strokes.
