fucking bike wont stop bogging at low speed its not the carb inlet or reeds all have been checked swaped from a working bike nothing its not the plug cdi or coil the same has been done with them i cant think what else it could be is onley until 10mph then its fine fast as fuck actuall p.s its a 172lc runner all help appreciated thanks steve
no mate this is not a drive train fault you can hear that its the engine doesent want to rev up until 10-15mph cheers steve
i cleaned the whole carb today it has always had this problem even before i ot it cab is fine main 99 idle atomiser 60 slow jet 55 it doesent idle very well either and if you try o pull off quick it cuts out steve
mine does the exact same thing does a fat powerband kick in at like 10-15mph then its speeds along and bogs abit at top speed? if it does i changed my carb and now its fine
its been said many times but turn the idle mix out 3/4 of a turn.. if this doesent vcure it the rolelrs are worn or you have a shagged clutch
right i will get back to all of you in on the weekend i will spend another hour with the carb and check the rollers clutch etc cheers steve
on the subject of bogging. when i put my malossi e5 airfilter on my bike it just bogged really bad i pulled the throttle back and it bogged and cut out it wudnt move anywhere. how do i stop it from bogging down thanks alot
