Bogging on Hills, have I gone too big on jet?
Discussion in 'The Workshop' started by b3n155, Jul 8, 2013.
  1. b3n155
    b3n155 New Member
    Hi All,
    I recently bought an 08 Speedfight 50. It ran like a dog when I bought it, but through cleaning/unblocking everything, I got it going pretty well again...
    Or so I thought....
    It was so flat when I bought it I couldn't pull away on a hill, and some hills simply couldn't get up.
    I have done:
    Carb cleaned, all the way through. Checked for blockages in vacuum tap, fuel and oil lines, all ok.
    Air filter cleaned.
    Exhaust De-clogged (this was the real breakthrough)
    After all this, it ran ok, however after a long period flat out (say 25 seconds) it would start to cough. If you release the throttle, it would be fine again. I put this down to too small a jet in the carb. I have found the scoot is de-restricted, however it only had a 54 jet in the carb, and normal would be to go up to a 55-56 (from 50).
    So, now, I've been using it fine for a few days, but when going up hills, it's now starting to bog after a short time flat out. Almost like it's flooding.
    Have I gone too big now?
    I also bought a second hand tuned exhaust. This says to jet up, but I have yet to fit it as it didn't come with the right bracket.
    Should I jet back down until I get the new pipe on, or is this unrelated?
    Ben
  2. xranekx
    xranekx New Member
    Going uphill slow can mean too heavy rollers. And a 50 jet for a 50cc with sports exhaust seems a bit to low tbh... except from going woot on a flat then check the plug I dunno what else to say..
    Sent from my GT-N7100 using Tapatalk HD
