my 2011 aerox bogs out when i sit at high revs for about 1 minute, all powers lost just makes that 'air sucking in' noise (if anyone gets what i mean)? when i stop turn the engine off and restart it goes fine until i full rev it. any suggestions on what to check/ how to fix ect? thanks
thanks for the quick reply. and i have the jets shall i try going up to the next size? also shall i clean my airbox + carb out aswell?
yeah givw it all a clean out and up jet and if it still dose it take the plug out after its done it and see if its wet or dry
actually before up jeting it take it for a run let it do it then check the plug to see if its wet or dry
soz for late reply went for a blast on my bike but yes its lean so up jet it a few sizes and see how it gose
just looked an my airbox wasnt fitted on the top connector had fell out of the top of the airbox, thought it had got louder recently, cleaning carb + airbox now see how it goes
If you think about it logically: When you're at full throttle, you're using lots of fuel, air and generating heat. The first thing I'd check is that the fuel lines can provide enough supply to maintain the high usage (makes sense that it has time to refill if you aren't at full throttle or stop to let it refill). Check the fuel vacuum tap and that the carb float can move freely. If you find no problem, give the air filter a good clean and try a cold/hot compression test (should be higher compression when hot)
had a similar issue with a zip 70 SP. It was the mixture!...bit of fine tuning with the screw soon sorted it out
