Blata B1 mini bike
Discussion in 'For Sale' started by m1tch, Feb 24, 2012.
  1. m1tch
    m1tch Member
    Hi all
    I am going to sell one of my mini bikes, the bike in question has just had a full top end rebuild done on it and annoying has more compression than my modded mini bike I also have! I just need to sort out the idle screw on the carb as I have just cleaned out the OEM carb and need to just set it. This is the project bike I have decided to sell, I am now building a bike engined kart instead!
    Please note that this is a Blata B1 rep - its a 37cc watercooled 2 stroke @ around 8bhp, it is NOT cheap 49cc air cooled bikes produce around 2.5bhp.
    Parts for this bike are very easy to come by (a piston, ring, pin and bearing is £11). There is also a 'big bore' kit available to bring it up to 49cc increasing the power to around 11bhp - crazy power for such a small bike!
    Parts can be found here:
    http://www.petrolscooter.co.uk/spare...led-parts.html
    and
    http://www.funbikes.co.uk/sc-Origami...ares-13-0.aspx
    I am looking for £150 collected, the bike itself is basically standard, I have done gasket matching, the head has been modded to have slightly larger waterways (good for cooling!), I have also chamfered the edge of the ports to reduce ring wear and polished the exhaust runner. I also believe it is fitted with heavier springs so it engages later in the RPM band giving better acceleration.
    This bike has helped me learn loads on rebuilding and 2 stroke engines, it would give me the confidence to be able to rebuild other 2 stroke engines like many on this site.
    THIS IS AN OFF ROAD ONLY BIKE
