BIT of carb setup help needed
Discussion in 'The Workshop' started by rider4life, Jun 10, 2008.
  1. rider4life
    rider4life New Member
    right went for the startup today on the 172 after rebuild, it starts, idles and revs really well when chokes on. (phbl 25mm carb), but when i take choke off the bike just bogs down and dies, even if i rev it. i will find out what jets i got in there tomorrow but does any1 kno what it could be.
  2. kyle1b1
    is obviously too lean :msn1:
  3. shiny red
    shiny red New Member
    read minors carb tuning guide start from scratch and be patient with it?drop the circlip on the needle to the top or first slot from the blunt end and go from there?
    so satisfying when you get it just right(or what you think is just right) :D
  4. rider4life
    first off what are 1 . 2 and 3 .
    it says 60 on the side of number one
    50 on the top of number two
    and aq266 on the side of number 3.
    the slide pin is on the bottom 4th notch.
    The bike kickstarts first time without choke and runs really lumpy. it revs fine but when i ride it hasent got no pull really. when i had this carb on my old 172 it felt the same and when i put standard carb on the bike was flying.
  5. Martin
    Martin New Member
    you really shouldnt of changed the carb youself if you dont know what each of those are (not being harsh)
    hope you get it sorted, read the guide!
  6. rider4life
    i can do it with sum guidence, ive never been a carb person. can rebuild engines all day long.
  7. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    hes alright hes not thik ave a look at his project ffs, lol anyway need to sort out main jets, get a 98 to say a 108 and worst ways ill coem help you.
  8. kyle1b1
    no need to touch those.
    like i said its too lean :msn1:
    if it bogs from idle when you rev richin idle mix if it bogs middle throttle drop the needle or if it is full main jet needs higthing.
    like i said is lean,
  9. Martin
    Martin New Member
    my bad, thought you were another random guy without a clue asking about jetting :w00t:
    seem to be alot of those.
  10. MiNoR cOnFuSiOn
    how hard is it to google "dellorto" first couple links will find you an itemised breakdown of the carb and its parts.
  11. rider4life
    thanks for ur help minor as always ;)
  12. rider4life
    its got a 120 main jet. u think thats to big
