bikes bogging like mad
Discussion in 'The Workshop' started by looxor-lad, May 22, 2009.
  1. looxor-lad
    looxor-lad New Member
    pug looxor 02
    well got the pug to start now starts first kick. i fitted an open filter to t and have had the jet re drilled by my local ped shop to match it however it is bogging real bad like just touch the throttle rev it a little then it goes to cut out. it will sit and idle fine but wont pull or let it rev out. fuel is getting to it etc. could the fuel jet have something to do with it?
  2. bertie
    bertie Active Member
    '93 Skipper LX125
    Sounds like its running extreamly lean which means the jetting is wrong. buy a box of jets and fit the correct size. Also lighten the rollers half a gram when fitting a air filter
