Bike smokes WAY too much, plug not fouled?
Discussion in 'Maxiscooter Tuning' started by WOLFFY, Apr 12, 2010.
  1. WOLFFY
    WOLFFY New Member
    Basically, Since I have had my bike, if I leave it for anytime longer than 45 minutes, when I start it up it smokes like a good'un for at least 5 minutes. It can be embarrassing some times!
    I've checked the plug and its running spot on, not oiling up or nothing. Thought it could have maybe been the rings? but the amount of compression coming from the exhaust is un-real.
    Once it's warmed up its fine, it has ALOT of bottom end power, beats all of my mates 172's with carbs and pipes up to about 55mph. I just can't get my head around why it smokes so much? Was thinking about the oil pump could have been turned up? And I've only ever put Shell VSX oil in it. If any one has any ideas of what it could be, would be appreciated :)
    (I did a search, but nothing like this came back)
    Thanks, Conor.
  2. 125TypHXR
    125TypHXR Member
    most two stroke engines smoke when cold. A few minutes. Once the engine warms up, the smoking stops. The problem is when it doesn't stop.
  3. MiNoR cOnFuSiOn
    id change the oil p[ump... if it still does it then ye its just the warm up smoke... if its a pump system they tend to "collect" alot of oil in the bottom end... this is obviously whats burning off...
  4. monty9120
    monty9120 Active Member
    Vespa gts300
    when i was abroad i hired a 125 out and it was so quick up to 50 it was unreal. it did the same thing it always smoked but it ran fast as fuck so i didnt care
  5. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    might have a load of carbon and oily residue built up in the pipe.
    could always try to clean it out.
  6. WOLFFY
    WOLFFY New Member
    I did think it was warm up smoke, but the smoke can be quite thick at times and I've never had any peds smoke like this? So yeah, will source a new pump tomorrow, as far as I can remember it is a pretty straight forward swap over? Thanks for the help :thumbsup:
    Will get it off tomorrow and attempt to clean it out haha, any ideas? I woulda said soak it with petrol? Will have a quick look on google haha. again, thanks pal :)
  7. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    yep petrol :) , or take it for a long thrashing, but if you do change pumps dont forget to bleed the oil! :hello:
  8. WOLFFY
    WOLFFY New Member
    Cheers J :) and LOLOL it gets thrashed for 15 minutes twice a day on the A127 haha but I never hold it flat out for more than like 5 seconds :)
    Yeah I'm not gonna forget about that!! :amen:
  9. monty9120
    Vespa gts300
    leave the oil pump as it is. someone could have used shit oil thats sitting in the exhaust pipe. this will cause the same problems
    its running fine leave it for now
  10. m1ck_t
    alot of shit
    coustic soda from wilkinsons ;)
    or burn it out with gas torches
  11. WOLFFY
    WOLFFY New Member
    Well I got a gas torch thing here. its one of the refillable ones? will that be any good? Gonna give it a go now anyways :) cheers again
  12. m1ck_t
    alot of shit
    them "GOSYSTEM" things?
    good for most things but won't get hot enough to do this jobby
  13. WOLFFY
    WOLFFY New Member
    Okay so took pipe off, scraped as much out of the downpipe as I could, then put the blow torch on it, wasn't the best job in the world, but got rid of most (about a week ago) it's now getting really bad. The bike always smells of petrol, is eating spark plugs, down on power, and is smoking twice as much now, and got to the point where I'm at a traffic lights any longer then 30 seconds it just chokes up, coughs and splutters when I pull away. One of the lads at work has got a series 1/2 engine in pieces, said hes gonna bring the oil pump in thursday, will the be okay on my bike? Thanks.
  14. nrgandy
    nrgandy New Member
    run premic instead oil pumps always fuck up i hate them
  15. WOLFFY
    WOLFFY New Member
    Okay, So I took the carb off, checked the main jet and its a 96, but as I undone the float bowl a bit and waited for petrol to drain out, it just didn't stop, and it was coming out pretty fast! so took the bowl off, checked the float etc, made sure it was all correct, stopped pissing out after that, but still has a strong smell of petrol, and the plug is ALWAYS wet? put a air filter on it, the needle was on the top notch, so put it down 1, does pretty much the same as but louder (sounds like a dog, smokes etc) took the filter off, but kept the rubber that connects to airbox pointing up, and it runs sweet as nut (still smokes and is a c**t to start) gonna bang a 105 jet in it an put the filter on and see what thats saying.
  16. WOLFFY
    WOLFFY New Member
    Banged a 25mm on my bike last night, open filter, 105 main jet, again, running weird, would run good with choke on but not off?? took the air filter off an run okay. took a picture of the plug after. its a bit darker than the picture (flash) seems to be a bit lean?
