Bike Reving to much and not ticking over
Discussion in 'The Workshop' started by Stennett, May 30, 2007.
  1. Stennett
    Stennett New Member
    Drive a 106 :(
    guys when my blet snapped a couple of weeks ago i got a new belt a cluttch springs fitted and the bloke that did it changed my needle in my carb or something as it says so in the molassi book that come with my 70 kit but ever sinnce the bike hasnt ticked over so how can i check the needle is at the final point . Also i had some 5.5 rollers but chnge them to 6.1 but my bike is reving more its re ing at like 10k revs how can i cange these ?
  2. px166bajaj
    px166bajaj Active Member
    Sounds like there may be an air leak on the inlet side. Did your mechanic replace the carburettor gaskets?
  3. Stennett
    Stennett New Member
    Drive a 106 :(
    i dont think so how do i get to te needle to check ? is it near the throtle cable attaches to the carn suroded by a spring ?
  4. px166bajaj
    It's inside the carb, mate. You'll have to dismantle the carb to get to it.
    I managed to get to mine without taking the carb off the bike, but thats a Malaguti. Yours may be different.
  5. capri dave
    capri dave Active Member
    You need to unscrew the top off your carb and pull the slide out,
    (The small cylinder attatched to your throttle cable)
    The needle is attatched to the bottom of the slide, by means of a clip.
    The needle usually has 3 grooves in it and you can position the clip into any of the 3 grooves to alter the mid range fuelling.
    if you were to adjust the needle to its top setting/notch youd weaken the mixture.
    setting the needle to a lower clip position would richen the mixture. :D
