bike loseing revs
Discussion in 'The Workshop' started by danny-p, Sep 12, 2010.
  1. danny-p
    danny-p Member
    SMC NMF 90cc
    today when i was riding my boke i kept loseing revs and sometimes rhe revs get stuck at full speed and didnt stop un till i turned the bike on and off 5 times any advice would be great?
    thanks danny
  2. capri dave
    capri dave Active Member
    I would be taking the tranny case off and giving the transmission components a look over as my 1st port of call :)
    also when was the spark plug last changed?
  3. danny-p
    danny-p Member
    SMC NMF 90cc
    thanks and the spark plug was changed at the start of summer
  4. capri dave
    try a new plug then as a matter of elimination...
  5. danny-p
    danny-p Member
    SMC NMF 90cc
    will do thanks for the help
  6. danny-p
    danny-p Member
    SMC NMF 90cc
    a friend at work said that it might be dirty pertol would that do it because i think i put 2strok in oops :lol:
  7. bertie
    bertie Active Member
    '93 Skipper LX125
    Highly unlikly to be old petrol.. Ive ran petrol thats been sitting in a shed for over a year in a jerry can, without problems.
    When you say loosing revs do you mean bogging down? If its getting stuck on full throttle then your throttle is sticking.
  8. danny-p
    danny-p Member
    SMC NMF 90cc
    yea but its allso reving by its self like i can do a no hander and it will go at about 5-10 mph by its self but when it gets into dop gear its fine
    i am puzzeld :confused:
  9. capri dave
    if it revs by itself...more than likely an air leak.
  10. danny-p
    danny-p Member
    SMC NMF 90cc
    if it revs by itself...more than likely an air leak.[/quote]
    fuck how would i go about fixig this
  11. danny-p
    danny-p Member
    SMC NMF 90cc
    it not old petrol but its 2stroke mixed petrol and my bike is straight petrol
  12. capri dave
    fuck how would i go about fixig this[/quote]
    you would fix it by finding out where the air leak is, and putting it right :)
    i.e a cracked/split inlet manifold, loose fitting carb, vac line off or split etc etc etc
  13. danny-p
    danny-p Member
    SMC NMF 90cc
    thanks caprie dave
  14. gabe502000
    gabe502000 New Member
    07 Yamaha C3 Scooter
    i.e a cracked/split inlet manifold, loose fitting carb, vac line off or split etc etc etc[/quote]
    Here's a diagnostic trick I learned working on aircraft: Get a can of WD-40 + attach the red plastic wand. Spray it on, and around, each part of your intake system. When your engine's idle speed suddenly changes, you've found the area where your leak is located. Gabe
