Ok I've got a bit of cash, so I want to make a order, firstly I think ill go for a 21mm carb as they are the same price as the 19mm Secondly does anyone no what jets I should be looking at, with a openairfilter and my setup which is below this is the carb I want to get http://scooter-center.com/catalog/produ ... =4403_4413 Now what manifold should I get, and would it be worth me getting a reedblock? I was thinking of this as terr0 showed me it http://scooter-center.com/catalog/produ ... 2_240_3195 However it is out of stock and I don't think it will fit the carb I want this one looks pretty much the same http://www.scooter-attack.com/shop/arti ... navigation Scoot-cent has the carb in stock but not the manifold, scooter attack is the other way arround
can be used on 50s if thats what you mean...the malossi mhr ones for the 50's are 28mm... i have the carb on its own but you may need filter and manifold, 25 quid, www.sip-scootershop.com item number M1611775
Is this all I will need reedblock: http://www.sip-scootershop.com/pages/de ... 7e452eb925 Manifold : http://www.sip-scootershop.com/pages/de ... 7e452eb925 Carb: http://www.sip-scootershop.com/pages/de ... 7e452eb925 Airfilter: http://www.sip-scootershop.com/pages/de ... 7e452eb925 So what happens with, oil and joke, issit still oil pump, or do I still hgave to do a complete premix and will I have a manuel choke or what What jet size does the carb come with?
no idea wt jet you will need tbh n not sure wts in it atm lol...but you dont need a reed block...just filter + manifold...think you can use the seperate oil line so dont think you need 2 premix..manual choke
and get a reedblock m8, mhr only like £33 worth it, seems pointless not to get 1 if your buying a carb
Oil MALOSSI 7.1, 1000ml Carburetor DELL`ORTO PHBG 21mm Belt POLINI Peugeot - Sachs - Reed Valve Block RRP Racing RRP Racing manifold Racing air filter HELIX Nut variomatic Peugeot 50cc Jet DELL'ORTO, PHB 92 Jet DELL'ORTO, PHB 95 Jet DELL'ORTO, PHB 98 Jet DELL'ORTO, PHB 100
Firsly whatever you do don't bloody order that air filter. It's fucking shocking. The reedblock is VERY restrictive on Peugeot engines which is why i said you should go for that reedblock, manifold, etc kit. It's also bloody cheap.
yer apprently the one you showed me if shockingly bad and the rrp ones are really good. Ok can you suggest any air filters i should go for that also look and sound nice
I have NEVER seen a big bhp peugeot engine running a standard style reedblock which is just what the RRP one is. If they are good for 20 odd bhp they can't be bad. Well that's normally with modding a V-force to fit but it's the same design. A proper sized reedblock spaced out from the standard reedblock. All air filters sound pretty much the same. Any full foam filter is good.
I've never seen a big bhp pug motor that runs formore than 10 seconds without self destructing, actully never seen one full stop.
