iv just finished setting up my aerox which goes really well for a 50cc iv got a derestricted doppler s3r polini variator + rollers polini air filter pm tuning reed valve but still the standard 12mm gurtner carb upjetted to a 78mj but iv noticed that i can upgrade to a 17.5mm quite cheaply and wondered if i would benefit much? thanks
if you buy a bigger carb then you will notice quite a change in sound and petrol consumption, a bigger carb will give it better speed but u will also feel a slight boggin, this is what happens on my typhoon and that has a 21mm mallosi carb on, have to build the throttle up slowly
personally a bigger carb isnt needed for a 50cc whereas if u had a 70cc kit it would be a different story mate, i use 2 have mine with the same setup as you and it did me fine till i wanted more speed and power so went for 70cc kit. its not worth putting a bigger carb on in my opinion!
17.5 will be ok with a 50..some 50s run them standard dont they ? but as steve said.. only really noticable with sumthing like a 70 kit ben.
deffinately get a bigger carb, mines a 12 ml and you can feel its restricting the 70 kit's power big time :emb:
ooh jamie get that 12mm changed...i ran my 70 set up with the 12mm for a few weeks.. Then when i bolted a 20.5mm on it was smiles all round
im thinkin of gettin a pmtuning 70 kit and upgrading to a 17.5mm carb off an old aerox, 2 things im unsure of tho... is there anything il need to change for the different carb to fit/function properly. what jet size do you think il need? baring in mind il have a 70kit, polini filter and derestricted doppler s3r? thanks
if your going to get a 70 kit i wouldent bother getting a 17.5mm carb you should go all the way and get a 21mm carb it will save you money
going faster always does... if you wanna keep the fuel usage down dont tune it.. if your gonna do sommin, do it right
yeh fair point but i still cant see how it will save me money arc: how much better will a 21mm carb be for the setup i want? and what jet size would you reccommend? as i would not even know where to start... thanks
:w00t: its because with a bigger carb it throws too much fuel into cylinder and it melts the barrel wall. :wtf:
