big problem
Discussion in 'Newbie Scooter Tuning' started by leviyz85, Dec 14, 2010.
  1. leviyz85
    leviyz85 New Member
    yamaha neos 50
    im doin my yamaha neos 70 kit you no all the bits BUT
    i need to know about the gearing some 1 said just get a Primary Gear Kit but obv if i get that i must need a secondary Gear Kit to mix with it and will
    and if so will i need to get a new clutch rod thing so the teeth on it will fit to the secondary Gear ??
    and will i need a new gear cover because iv seen the Malossi Race Gear Box Casing - £75
    i dont realy wona buy one but if i need to i need to
    thanks levi
  2. tErr0
    That is a totally useless topic title. Change it.
    You should use the search before making any new topic.
    http://www.scootershack.co.uk/viewtopic.php?p=71453#p71453
    http://www.scootershack.co.uk/viewtopic.php?p=8786#p8786
    To put it in simple terms as this is newbie tuning... You only need one gear up and you should buy the primary gear up as you can buy pre-pressed ones from stage6 that slot straight in.
    The first post I linked to explains how the gears are put together so answers your second question.
    You don't need a gear cover. The key is in the title of it. It's a race part and is only needed on race spec bikes.
