big bore kits, is it worth the cost
Discussion in 'Scooter Tuning' started by foster, Dec 9, 2007.
  1. foster
    foster New Member
    from what it seems you lot all seem to have big bore kits. but from what i heard they wreck your engine in a couple of months. is this true or is it jst a load of crap. is their other mods you have to do in order to ride with damaging your engine with a big bore kit.
    piaggio nrg power 50cc
  2. Dann
    Dann New Member
    Depends if you know how to fit them or not.
    Change your avatar WAY TO BIG!
  3. foster
    foster New Member
    well im not gunna fit it . i'll get a bike mechcanic to do it for me. so it should be done properly
    lol yer i no, jst relized........ its gone now :p
  4. harrisp
    harrisp New Member
    Also if the crank has a lot of miles on it then it might be worth changing.
  5. Haresign
    Haresign New Member
    GPR50 + Peugeot 307
    If you run it in properly and get it set up correctly (Jetting, mixture etc.) then they last for 1000's of miles.
    I can't really talk as mine seems to break down every 2 miles,
    Don't let this put you off though :p It's cos I'm a dumb ass and not built it right, all good now though.
  6. capri dave
    capri dave Active Member
    if you buy and fit properly something like a polini/malossi cast iron sports kit,
    run it in properly...and use good 2 stroke oil...and dont rag it when its cold..
    And of course the bottom end is healthy and has plenty of life left on it..
    Then...it should be no less reliable than the std barrell and piston ;)
    problems occur with big bore kits when 1 or more of the above are not adhered to :D
  7. zumaman
    zumaman New Member
    How do you guys run it in?
  8. BeeWizz
    BeeWizz New Member
    Hey guys i worry the same as zumaman im wanting to buy/install a 70cc kt but worry that it will blow the engine or sumink:/ everything on my bike is stock except i have ligter rollers and a dopler S3R exhaust on it btw does the milage of the bike make a diffrence to how long it will last with a 70cc kit?
  9. Hursty
    Hursty New Member
    depends on milage of the bike.. a bike over 10,000 miles.. personally i would do the crank if ure doing a 70 kit..
    but if u run it in right.. use good oil and use a GOOD 70 kit.. i.e malossi sport or polini sport u could get a good 20,000+ miles from it then its a simple piston ring change.. (so im told)
    ofc its worth it...
    ben.
  10. BeeWizz
    BeeWizz New Member
    My bikes done just over 5500 miles so its all good yer(Y)
    Id want a kit that has good reliability any ideas???
    and would ther be anything els that would need to be installed to get the best out of it?
  11. kyle1b1
    a sport kit would be the best for reliability and for getting most out of it all depends on money like everything :D
    decent pipe, bigger carb, porting
  12. foster
    foster New Member
    cheers for all the info. mines only done under 3k millage so it not really worn, and i found a page on this website telling you all the mods for a budget tuning so i will probably follow the cheapest one :p
    seems i'll hav to get it in stages, buying an fitting the bore kit first shouldn't cause any damage to the engine?? ( if i wear it in and a mechanic fits it for me) bearing in mind their will be about a months gap between being able to get the rest of the stuff.
  13. waxhead
    waxhead Member
    Im putting a 70cc kit on my scooter
    Its an ebay cheapy but i am not worried i have measured up the porting and its a 180 degree exhaust with a 117 transfer cylinder
    i will up the transfer port duration a small amount and run my genalli pipe
    17.5 mm carb and carbon reed
    I will also blend in the cases as they are shocking
    If it all goes wrong in time to come i will put making a 133cc out of it anyway
    the 45mm crank goes straiaght into my cases with no issues
    Got to love the chinese copies
  14. steve-k
    steve-k New Member
    i wouldnt go for a cheap tuning setup because they can be lots of trouble, go for a polini sport 70cc kit there more reliable.
    dont forget that its better to have a pipe which is useable with 70cc kits so the doppler s3r and yasuni etc. are the best to go for.
  15. MiNoR cOnFuSiOn
    if its a gianelli reverswe you have it will be fine for a sport kit.. ive had better results with the gianelli than any other pipe on an iron 70 kit ;) anything other than the reverse isnt worth the metal its made from tbh
  16. waxhead
    waxhead Member
    Its a next pipe
    i am wondering where that fits in with the reverse if its a higher or lower rev pipe
  17. MiNoR cOnFuSiOn
    havent used a next but i do belive its rated below the reverse (or is the replacment) ether way its always best to experiment with the transmission to gain best results from a barrel/pipe match as the powerband is dependant on the ports vs the pipe and you want the engine to rev at this rpm at full throttle at any speed.
  18. DRJ-Performance
    DRJ-Performance New Member
    My NRG had the 7 port MHR Race 70 Kit and I did 3500Km on it before it came off the road, I'd say there was still a good 1500km left in it before I rebored or stuck a new ring on it.
  19. westey boi
    westey boi New Member
    hay ime new to this but i no abit about peds.big bore kits will blow ur engine up in proper run in or just to much strain on the engine.
  20. wobbly_trials
    #1, you make no sense mate, read it back and retype it
    #2, bore kits only blow our engine if incorrectly fitted or fitted to an already weak engine, there will always be a reliability tradeoff when power in involved, however, good workmanship and workshop practice can make this tradeoff a lot less aparrant.
    i can make an iron 70 kit las just as long as a stock engine with the right parts.
