Best tuning setup
Discussion in 'Newbie Scooter Tuning' started by Volius, Sep 7, 2010.
  1. Volius
    Volius New Member
    Hey,
    What is the best setup to tune a 07 NRG power DT without fitting a bore kit. tere is no budjet.
    thanks x
  2. capri dave
    capri dave Active Member
    without fitting a 70cc kit, your not really going to set the world on fire tuning wise im afraid....A 70cc kit represents the best bang for your buck :)
    but if your adamant heres a list of things you can fit to a 50cc:
    sports pipe, Variator, Rollers, clutch springs, aftermarket reed block with carbon reeds, sponge filter insert for std air box.
    and go over your bike making sure you havent got any restrictions in your air box or inlet manifold...
    But i would pick a 70 kit over all those things as a starting point personally :glare:
  3. DASH.
    DASH. New Member
    Zip 70.
    aggreed if money is not an issue then why are you not getting a 70s kit?
  4. Volius
    Volius New Member
    Because i haven't got the time to spend fitting the 70's kit, the scooter is used for commuting you see.
  5. DASH.
    DASH. New Member
    Zip 70.
    its an hour job?
  6. bertie
    bertie Active Member
    '93 Skipper LX125
    Get a sport 70 kit for everyday use, best bang for buck and will work with standard carb upjetted to suit. Cheaper than buying a good sports pipe too.
