hi, just bought new aerox, well second hand but all fully standard and i am looking to do my ped up wiv a set up so it is extremely talky, as in its got a straight away pull off, and i was wondering if anyone would kindly let me in on their setups for the most torque, as in what bore, carb, clutch, variator, pullys, talk drive etc etc would be the best to use together for the set up, if anyone would kindly help i be extremely grateful, thanks, **Greengoblin**
FUCK messing about with a "torquey" setup, the transmission in an auto scooter will make up for a torque shortfall anyway, just set the clutch springs to bite at the right point so it don't bog down on takeoff, get the correct roller weights and a larger carb. Obviously you'll be wanting a 70 kit and a pipe, so use the barrel + pipe matching guide Swift made and you won't go far wrong. Also consider a malossi multivar variator, torque pulley and uprated clutch cause a torque pulley will destroy a stock one.
