best set up for neos?
Discussion in 'The Workshop' started by eddo241, Jul 6, 2010.
  1. eddo241
    eddo241 Member
    NEOS
    fitted racing clutch blue springs (v hard) and torque spring medium stiff+6g rollers,now engine sounds like a steam engine-chug,chug on accel then sounds normal then again any ideas on best set up 2 avoid this wrong cllutch n torque set up?
    standard 50cc motor
  2. capri dave
    capri dave Active Member
    chug chug like a steam engine :confused:cratch:
  3. eddo241
    eddo241 Member
    NEOS
    speeds up nice then motor keeps same speed but sounds like a chug,chug then goes normal, then does it again at top end sounds like a 2stroke with no probs didnt do it with old clutch torqe spring n rollers
  4. capri dave
    fitting lighter or heavier rollers will alter how fast the front pulley opens, fitting a stiffer or weaker contra spring will alter how fast the rear pulley opens....
    also a stiffer contra spring will push the drive belt back up the rear pulley (to the start position) faster as you start to slow down again.
    when you fit a stiffer contra spring, in most cases you have to fit heavier rollers...
    what happens is the stiffer contra spring will cause the rear pulley halves to squeeze the belt harder, the belt will move down the rear pulley slower, and it will feel like the engine is revving harder....heavier rollers will exert more pressure, pulling the belt down the rear pulley quicker counter acting the stiffer contra spring :)
    why did you change the contra spring and rollers ? you only really need to fit a stiffer contra spring if you are experiancing belt slip due to a big rise in power/tuning...
  5. eddo241
    eddo241 Member
    NEOS
    contra spring that was in it was warped from the heat of the damaged bearings, also backed the nut off rear wheel,to take it off when i tightened nut back up rear brake seems to be applying slightly?
  6. capri dave
    sounds like youve got a sticky piston in your caliper, the faster you go the tighter the brake will grab, due to heat expansion....you need to get the caliper sorted before you proceed any further :)
  7. eddo241
    eddo241 Member
    NEOS
    Have fitted new top end still pulls away far to slow only gets 22 up hill have blue springs in clutch n standard main spring any ideas?
