best pipe
Discussion in 'Newbie Scooter Tuning' started by antman1992, Jul 23, 2011.
  1. antman1992
    antman1992 Member
    Aerox
    Hey guys what would the best pipe be for a yamaha aerox 50cc with stock engine? most probally will stay stock engine if i do upgrade i would buy a complete new pipe
    also with the pipe you have suggested what would i have to upjet my carb by?
    Thank you
  2. RelentlessDan
    RelentlessDan New Member
    upjetting varies from 5-10% normally, start high, get lower til you find the best jet. just buy a box.
    there's loads of pipes you could have so its entirelly up to you really.
    So instead of listing the pipes i would personally recommend, ill list ones i wouldnt:
    Technigas
    Endy
    Ninja
    Hebo
    PM Tuning
    Leo Vince TT (its an okay pipe, but its also the cheapest and worse looking of the aftermarket exhausts and you should really just spend some extra and get something decent)
    Any cheap brand you find online
    Look for something like a stage 6 exhaust, Gianelli, Yasuni Z, those kind of pipes.
    Nothing too revvy bear in mind. and you will need lighter rollers, bigger jet and maybe stiffer springs, you cannot stay COMPLETELY stock bar the pipe
  3. Jonnymarrw00t
    Piaggio Zip 05 plate
    Nothing wrong with the hebo or tt ? If you're on a budget go for a tt. If not go for a Yasuni z if you intend to go for a low end 70's in future (Like polini corsa) Go for a Yasuni R. You will need to change your rollers and upjet. Use the Jetting and rollers guide to do so.
  4. benny1985
    benny1985 Member
    aprilia sonic gp 50
    i wood say the hebo had one on my old aprilia sonic same engine as the aerox pulled well not bad exhausts for under £100
  5. JerseyJim
    JerseyJim Member
    '99 Zip RST
    Hebo for under ton?? Where...!?!
  6. Jonnymarrw00t
    Where....? Do tell.
