best paint for transmision casing?
Discussion in 'General Scooter Discussion' started by ludixblaster, Dec 9, 2008.
  1. ludixblaster
    ludixblaster Member
    gilera runner 125sp
    will the halfords stuff be alright if i prime then spray it with that then laquer over the top?
  2. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    iv only ever sprayed a tranny case once, when i was 16.
    i used vht paint, had a good finish and was very long lasting, hard to chip and and didnt run when petrol or watever hit the surface
  3. ludixblaster
    ludixblaster Member
    gilera runner 125sp
    ok thanks mick
    if i cant find any of that heat proof paint from halfords will be the answer?
  4. m1ck_t
    alot of shit
    yeah any heat proof paint , the only reason i used it was because i thought it would be longer lasting, wich it had prooven to be, but defo apply a few coats of that laquer too
  5. nibbles
    nibbles Active Member
    hi there any rattle cans are fine m8 just use high build primer and make sure the casing is very clean .assuming youve stripped the paint if not and the original paint is still in good nick rough it up wiv 600 grit wet and dry primer paint and lacquer as usual .hope this helps get back to me if you dont uderstand or get stuck
    nibs
  6. MiNoR cOnFuSiOn
    come on people.. its metal
    ETCH primer.. THEN lots of red oxide.. THEN colour. if its flat high build primer isnt necisasary.. sand ya shit befor you even try painting it. needs to be perfectly clean aswell (pannel prep to clean befor you paint)
  7. m1ck_t
    alot of shit
    :emb:
  8. nibbles
    if its metal thats y i sed high build primer das all n theres more than one way to skin a cat lol ps dont be confused i have skinned a cat b4
  9. newbold-runner
    newbold-runner New Member
    your fucking weird
  10. MiNoR cOnFuSiOn
    if you had you would know its an ironic thing...
    see, you grab a cat, slice inside its leg's then straight from the neck to the tail, grab, and pull... so there is one way to skin a cat m8.
    :w00t:
  11. newbold-runner
    so if anyone is intrested in having frsh cat for a meal talk to chef minor on how to skin it
  12. MiNoR cOnFuSiOn
    well, i did live up north for a lil while...
  13. nibbles
    well done
  14. nibbles
    lols iv skinned rabbit gutted pheasent and trout and salmon and chicken and if its oat like that theres a few ways thats work and diffo techniques lols
  15. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    just remember the best paint to get is one that has a colour, lauquer alone is no good
  16. nibbles
    lols wot
  17. Jefr0-180
    Jefr0-180 Active Member
    Powdercoat anyone? lol
