Buying a 70cc kit for my Aerox 50 and was thinking about getting the Malossi MHR Replica 70cc.. was just wondering whether the Polini 70cc Sport or Stage6 70cc Pro were as good or better seeing as I've heard some people recommend them and also as they're slightly cheaper Cheers
the polini 70 sport as its ment for every day use, the mhr is ment for race and will only last 3000 mile if your lucky and you have to have better carb + exhaust + crank + gear up kit maybe even a new ignition. with the 70 kit you can keep every thing standard just up jet it thats all
Thanks a lot mate :good: , wasn't aware of that. So if i were to get the Polini 70cc, a better variator or carb wouldn't be necessary? Also which exhaust would you recommend? Had in mind a Yasuni Z (others are way too expensive) or a Stage6 Pro Replica as i read on some other forum that it was good
