Best 2 stroke
Discussion in 'The Workshop' started by J4CK, Jun 4, 2011.
  1. J4CK
    J4CK Member
    Piaggio NRG 172
    What is the best 2 stroke for Piaggio typhoon 125 also does V power unleaded do anything? thanks
  2. brettfield999
    brettfield999 Member
    Typhoon 172
    I have always used Putoline fully synthetic and the bottle I have at the moment is Putoline TT Scooter +. Make sure the one you pick up is suitable for autolube and not for premix only
  3. J4CK
    J4CK Member
    Piaggio NRG 172
    Ok mate thanks will it say for pre mix only on it?
  4. brettfield999
    Typhoon 172
    Soz i meant for if you can't get this brand make sure it says premix or auto lube. Putoline says in the bottom right corner "injector and premix". I've been back on scooters for 3 months and this is the same brand i used to use back when I was 17
  5. J4CK
    J4CK Member
    Piaggio NRG 172
    Ok thanks pal is castrol any good? and does that v power unleaded actually clean your engine or anything?
  6. brettfield999
    Typhoon 172
    I wouldn't use it for a 2T scoot mainly because I stick with what I know and they don't really specialise in 2T. Good oil for cars and 4T bikes. Vpower/Optimax. They say it decokes your engine but im not sure. I used to get miles better MPG from using it so its worth it. On an untuned scooter maybe every 5 tanks would be beneficial
  7. J4CK
    J4CK Member
    Piaggio NRG 172
    I was just thinking a full tank of it once a month or something i picked up a leaflet on it and it says its good for your engine and all of that stuff would you be able to find me a picture of which putoline i need to buy also is silkolene any good?
  8. brettfield999
    Typhoon 172
    Chuck this into ebay: 260689681191
    I've never used anything but Putoline for scooters but ive used Silkolene on bigger 4T geared bikes and its okay
  9. J4CK
    J4CK Member
    Piaggio NRG 172
    Ok thanks alot buddy one more question what gear box oil will i need in my typhoon 125 engine just planning on changing it :D
  10. brettfield999
    Typhoon 172
    never had to change the gearbox oil. I'm doing a fat rebuild on my Typh so i bought some Putoline scooter gear oil. I think they only make one. Its 75w90 125ml. I dont think you need it all though. Anything that is auto scooter gear oil is fine
  11. J4CK
    J4CK Member
    Piaggio NRG 172
    Ok mate thanks alot
