Benefits of running premix?
Discussion in 'General Tuning' started by Aaron Hastings, Jun 19, 2012.
  1. Aaron Hastings
    Aaron Hastings 125 KiLLa!
    Mk1 piaggio zip sp.
    Had my engine out today for a good clean and got it ready to put the polini sport and 21mm carb on it and i took my oil pump out to clean it and thought of premixing it instead from now on. Just wondering how you remove the gear as i just couldn't seem to get it out no matter what i done to it lol. It's on a piaggio zip sp mk1. Think all piaggio engines are all pretty alike so anyone that could explain to me what the benefits of running premix are and how i could get this bloody oil pump gear out it is much appreciated!! :)
    thanks
    aaron
  2. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    No idea about the pump drive on piaggios, but I premix my aerox just because I don't trust the oil pump, and its not worth ruining my crank and cylinder because I couldn't be arsed to premix :p
    You will need to go up one size on the main jet though
  3. Aaron Hastings
    Mk1 piaggio zip sp.
    Cheers mate, didn't know if it took any stress off the crank and gave a bit of increase on performance or anything?.. think my carb is slightly overjetted anyway
  4. FiddyRox
    Suppose it take a bit of resistance off the crank, probably not noticeable.
    Doesn't really add performance, but should be done as a precaution when tuning really
  5. caine aerox stalker
    caine aerox stalker Member
    i bought a aerox ova day and it premix i cant be arsed wi premix but is it better to premix or not
  6. Aaron Hastings
    Mk1 piaggio zip sp.
    From what ive heard its a lot better if you're tuning and worried your autolube isn't putting enough oil through
  7. Chubz
    Chubz Well-Known Member
    70cc Aerox 04'
    what id like to know is how you blank off the oil feed... ? like with what
  8. caine aerox stalker
    a screw
    Alpal likes this.
  9. Chubz
    70cc Aerox 04'
    Is that it ?
    ..On an aerox mind
  10. caine aerox stalker
    ye just screw a screw in the pipe
  11. Chubz
    70cc Aerox 04'
    gonna look into this then if its that simple....
    is it not well awkward when filling up at petrol stations ? lol
  12. Aaron Hastings
    Mk1 piaggio zip sp.
    I suppose it would be a bit awkward but what would you prefer an angry old man moaning because you're taking too long or a seized engine lool :/.
  13. Chubz
    70cc Aerox 04'
    haha good point... the old man would get told to piss off and go to another pump tbf. haha
    think im just gonna drop a bit of 2t into the petrol tank n give it a good shake with the oil pump still on
  14. Aaron Hastings
    Mk1 piaggio zip sp.
    would get far too much oil then lol.. ride down the road with blue clouds following you!
  15. caine aerox stalker
    just get a babys bottle lol it has 25mm to 100mm i mix 25mm to a litre so it simple get 3 litres then mix 75mm takes 5 min
  16. Chubz
    70cc Aerox 04'
    Im only on about the smallest bit so its only very slightly 'premixed' and obv still have the oil pump functioning as usual ?
  17. FiddyRox
    Just carry some measuring spoons under your seat, and your oil.
    At a petrol station you could just fill up, add the oil and shake the bike to mix it. I usually mix it in a separate container though.
  18. Chubz
    70cc Aerox 04'
    Thats wat im sayingg, fill up the bike as normal at the petty station, then open up ya seat drop a small bit of 2t in there shake it up a bit then zoom zoom.
  19. FiddyRox
    Yeah but it's got to be the correct amount
  20. Chubz
    70cc Aerox 04'
    even with the oil pump in action/fitted ?
    was just gonna tip a very small bit so its like 99.5% petrol .5% 2t, literally a drop of oil ?
    Im gonna get that Stage6 measuring jug thing from PP, how much would you say was ideal if iv still got the oil pump connected up ?
