been running in my malossi
Discussion in 'Maxiscooter Tuning' started by runner 180, Feb 15, 2008.
  1. runner 180
    runner 180 New Member
    i been running my malossi on full syn oil and search oil and look at a thread that says run in a new kit on semi syn oil so shuld i drain it and use semi syn oil search for it and tells what to run on but i want to no if i shuld drain use semi syn oil? thanks
  2. MiNoR cOnFuSiOn
    if its been run a couple times and been ridden for 20 odd miles its run in...
    rings dont take long to take the shape of the barrel.
  3. runner 180
    so minor i done 60 odd miles so it safe to go over 50 mph coz my last 1 heat sized cause i was goin 70 it steal work but kept cuttin out but i ever had the a/c casing over it and was running it on bulls**t oil
  4. Kieran
    Kieran Active Member
    st
    The a/c casing was off = heat seized.. lol
  5. runner 180
    lol ur funny u joke
  6. Anonymous
    Anonymous Guest
  7. MiNoR cOnFuSiOn
    its an explination.. fuck all to do with oul, you remove the cover an it will go bang.. simple
    rag it m8
  8. monty9120
    monty9120 Active Member
    Vespa gts300
    when the drag gets a 172. its getting a few miles and thats it
    i was meant to run my new 4 stroke engine in but i got bored :w00t:
    my 172 was still spanking even though i was doing 70 within an hour or 2 :pimp:
  9. MiNoR cOnFuSiOn
    said it a million times.. ali kits are race items, there made for this kind of use. does an f1 car get run in? hell no the engines built, ragged through qualifying then raced for a couple hours of non stop abuse.
    if it goes bang you didnt build it/set it up correctly..
  10. capri dave
    capri dave Active Member
    Hey likeing the F1 explanation minor!!!
    1st race 16th march boys...
    and yes back on topic...ali/nikasil bore very little run in req"d :D
