baotain qt50 de resricting
Discussion in 'The Workshop' started by aeroxrob, Jun 1, 2011.
  1. aeroxrob
    aeroxrob New Member
    i have a baotain 50 4t and cant figure out how to derestrict it i have changed the washer on the carb to the middle notch it has no pink wire to the cdi and there the two restictors and it still only goes 30 maybe 35 if i push it
  2. nathan93
    Gilera Ice
    cdis de restricted if your going 35 although mine did 40 with the wire cut
  3. lshigham
    lshigham Member
    Check for a washer in the variator to restrict travel, but they're painfully slow whatever you do.
  4. city-cumuter
    city-cumuter New Member
    mine does 45 easy 47 at a push cut pink wire and remove screw completly from the fuel jet , look on you tube loadsa videos
  5. 4strokelover
    4strokelover Active Member
    Longjia Raptor 200
    i have the same problem with mine :/ iv taken out all of the restrictions and everything else i got told would work bit still just about hits 40.. My opinion it that it could just be the baotian bikes lol if you want to go fast get a aprillia sr 125 them de restricted go 100mph ;)
