back tyer not puncherd but keeps on goin flat
Discussion in 'General Scooter Discussion' started by younger-rider, Jun 6, 2008.
  1. younger-rider
    younger-rider New Member
    :confused:arc: on my runner i got a dragster back wheel with a viper back tyer wen i pum it up with the valv init dnt go up when i take the valv out it pumps up then i have to put the valv in quickly the air is comeing out from the side the beem but iv took the tyer of cleaned it and the rim put reslear and it pupmps up then next day its flat fink its time for new wheel and tyer or can this be fixed
  2. WOLFFY
    WOLFFY New Member
    That stuff you spray into it?
    I used to have to put it in like every 3-4 days other wise I would have a flatty lol
  3. Nitro-Rhys
    Nitro-Rhys Active Member
    tyre may need resealing to the rim
  4. kyle1b1
    let tyre down.
    break the bead.
    clean rim up with sandpaper or wire brush then bead sealer on it then re-inflate.
  5. younger-rider
    done
    iv done all that i just keeps goin flat from the beem its blowing bobbles wen i put the sealer on
  6. sc_bk
    sc_bk New Member
    If the powder coating is all falling off then this will let air out
    The rim needs to be totally smooth
  7. wobbly_trials
    what kyle and sc_bk said, whip the tyre off, get some wet and dry, about 120 grit and some elbow grease, should get em nice and smooth, any ridges or loose paint/powdercoating will cause air leaks.
  8. nrgandy
    nrgandy New Member
    if you cant do it ureself whip it of go to local tyreplce and they will have it sorted in a few minutes cost me £5 on my old zip
