Back Brake Problem
Discussion in 'The Workshop' started by Duggiedan, Mar 22, 2012.
  1. Duggiedan
    Duggiedan Piaggio zip 50cc
    Piaggio Zip
    Hey Guy, I need to tighten my back brake as isnt really safe and need for wheelying! I know you need to grip the nut further up to stop the thread spinning and I can grip that but while trying to tighten it at end its not budging at all! ive sprayed wd-40 and nothing seems to work any tips?
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    if it's really that bad you're best off buying a repair kit.
  3. Stig
    Stig Well-Known Member
    EXUP1000
    Theres usually a square shank part on the cable that you can get a small size flat spanner on to stop it rotating.
    As above, give it a good soak in WD40 but then try to loosen it first to break the seal...then tighten. A quick wire brushing dont hurt the threads either to clean them up
    If all that fails, its a new cable needed, oh and it may also be the arm into the drum thats seized stopping the brake working so may need stripping and greasing
    Duggiedan likes this.
  4. roxy boy
    roxy boy Well-Known Member
    roxi
    ...why do zips have drum ...its a bit outdated and cheap ....do the new zips have drum ??
  5. Duggiedan
    Piaggio Zip
    jonny thanks but might sound stupid but never looked into it but how does repair kit sort it
  6. Duggiedan
    Piaggio Zip
    The brake works at fine just needs tightening for wheelies but gunna try again this morning thanks for help guys
  7. Jonnymarrw00t
  8. ramo
    ramo GoldMember
    They last longer than disk
    They're easier to set up than disk
    They're a lot cheaper to make/fix
    and IMO they work better on the back
  9. Duggiedan
    Piaggio Zip
    Update - Been out cleaning my bike as usual :D and i ford ill give it a go and try sort brake out so i just got mad, Took all panels off bike and Removed from Lever and Went and put in my vice clamp and undone it after a good tug so i soaked in wd-40 and wiped in oil before put back on and not nice and tight :) thanks for help! Btw im going to put pics of scooter in visual mods for you if u want to look
  10. Jonnymarrw00t
    put it in a project !
