found an athena alu 70 kit on beedspeed single ring dont have much info on it tho like power output or revs it runs at was wondering if anyone knows much about them and it go on a standard crank, if not i have a crank laying around that looks different from standard but im not sure what brand it is was wondering if anyone could help me if i get pic of the crank aswel?
get a pic of the crank, no single ring kit should be run on a stock shape crank (need a high compression full circle crank as single ring kits make more power high and less power at low revs, so your engines gonna get a beating, hence you need a well balanced crank to sit hapily at the new peak rpm) will also need a good pipe. get a pic of the crank you have, one of us will know what it is.
athena make the cylinder kits for stage 6 if its got a single exhaust port it will be a sport and if its got a bridged port it will be a racing.
beedspeed say they dont have that kit in stock anyway ill probly end up with another polini sport am curious about the airsal and dr kits tho scootercentre says the dr is more torquey than polinis and the cheap airsal one is alu is it still no good? and i cant figure out how to get pics on here for the crank so ill have to upload it somewhere and post a link
ye just upload it and link (theres a function that turns links into pictures on forums... quote somone with a picture's post and you will see the code, or go to the guide) airsal kits are ok once you dso a bit of work but i wouldent recomend one to somone to just bolt on, mine needed lots of work befor it even fitted (piston needed cutrting to clear the conrod, the head was a mess and the ports were all over the place, fucking moved once i sorted it tho) the dr kits aint too bad (just has more torqwue as the ports a little wider) cant go wrong wiht a polini kit tho.
