does anyone make a tuning front outer pulley wheel for 125 motors i have seen the stage 6 ones but believe they are for 50/70 motors i have searched the topics on here and browsed online but couldnt find any info cheers fellas
if your not fussed about electric start you can nock the toothed steel ring off the outside of the pulley... this makes it weigh 2/3 of original and helps with pickup. you cvan remove half the fins aswell altho this requires a laith, same with the flywheel, litening the load on the crank means quiucker pickup and more power comming off the crank.
minor your ace nocking that outer ring makes it well lighter and im getting my m8 to remove some of the fins on his laith. this mod i say is ace just gotta see what it performs like now
kyle ill do one more and swap it with ures if u want as it is hard to do it took me ages to get it moveing in the end i just got my 3 armd puller and off it poped
lucky i only finished makeing the tool and didnt use it ill have to dig out the old impact gun but i have heard of it knocking the crank out of line happend to my m8s bike so im not too sure
an impact wrench is less likely to nock the crank out of alighnment.. putting 52nm ACROSS the crank pin WILL twist it. never had trouble with an impact wrench, its idiots who sit there for 5 mins tightening it with one.
