Areox 100cc Electrical Problem 2002
Discussion in 'The Workshop' started by T&JCustomPeds, Feb 20, 2012.
  1. T&JCustomPeds
    T&JCustomPeds New Member
    Basicly the indecators work and the horn but nothing else... No electric start... No side lights... No brake lights
    I have worked out that the indicators and horn are on a Brown supply and the rest are on a Black supply... but no loose ends... no damaged cable (as far as i can see)
    Was thinking the rectifyer? i dont know...
    Any ideas?
  2. roxy boy
    roxy boy Well-Known Member
    roxi
  3. T&JCustomPeds
    There is only one fuse i can see... Comming straight from the batt?
  4. roxy boy
    roxi
    do they work when bike started
  5. T&JCustomPeds
    Carnt get it started with out the electric start...
  6. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    the bike needs to be running for the headlight and tail light to work bud
  7. T&JCustomPeds
    Even the brake light? I am sure i remember my 50 areox even when the engine was off but ignition is on the brake light still worked?
    Is this differnt to the 100cc model?
    And if this is the case then it will be down to ethier the Starter Switch or Solinoid
  8. creamsodauk
    Runner 125 SP
    cant remember about the brake light, but i do know the number plate plight tail light and head light only run when the engines on
  9. Stathis
    Nrg Power 70cc
    at my 50cc nrg when its off the brake light if you push it comes on, same with indicators and horn but nothing else...
