Aprilia throttle cable confusion
Discussion in 'The Workshop' started by Hackett Sr, Jun 23, 2011.
  1. Hackett Sr
    Hackett Sr Member
    just got a new throttle cable for my aprilia sr 50 2009, half way down the old cable it splits off and goes into the engine casing, but my new one dosent do this, where does it go? :confused:
  2. simon1984tech
    simon1984tech Member
    speedfight 100
    im guessing your old one is a split one, one end goes to the oil pump the other end to the carb, i think you can just run the one you have to the carb but then you will have to premix your fuel with oil or send the cable you got back and get a split one, im not positive but think this is right same as my speedfight
  3. nathan93
    Gilera Ice
    basically what simon has said
    the old cable is split 1 part goes to the carb and the other to the oil pump, send it back if you want use of you oil pump or run premix,
  4. Hackett Sr
    Hackett Sr Member
    Okay cheers guys, i'll order a new one :grin:
