I have a project SR (1997 Minarelli WC), but the casings are a bit fucked. what other bikes use this engine? Cheers J
The aerox uses that engine so does the jog RR , also some early aprilia's ,and italjet's and as scubabiker says the a/c cases are the same as l/c as long as it is the minarreli horizontol motor just replace the air cooled fan with a aerox mechanical water pump and put the l/c top end on and away you
