Aprilia sr50 morini rear wheel nut ?
Discussion in 'The Workshop' started by 4strokelover, Oct 17, 2018.
  1. 4strokelover
    4strokelover Active Member
    Longjia Raptor 200
    Hi all and sorry if this is in the wrong place.
    Just asking if anyone knows the (morini engine) rear wheel nut size or know how to get measurements.
    I cant find any info on it as it only comes up with sizes for the (piaggio engine) and that nut it too bit.
    I had one but rolled down a drain and its lost forever lol
    Any help appreciated.
  2. MARSH
    Measure the diameter of the threaded shaft and threads per inch, or use a thread pitch gauge then off to a nut/bolt supplier !
  3. Sam phantom
    Sam phantom Active Member
    Minarreli/Yamaha engine is 22mm
  4. 4strokelover
    Longjia Raptor 200
    Thank you both.
    Ill try figure out how to do the measuring ect.
    Im not sure if the minarreli has the same size wheel shaft. I wish all aprillia engines used the same sizes as they used piaggio/ minarreli and morini engines.
  5. Sam phantom
    My bad, thought it was a mark1 Aprilia SR
  6. 4strokelover
    Longjia Raptor 200
    No worries mate.
    It was a aprilia sr50 R with the piaggio engine but was completely fooked so swap it out for the morini engine but lost the rear wheel nut lol
    Its so sad dropping somthing and litrally watching it role down a drain. Reflexes didnt kick in quick enough to grab it.
