Aprilia SR50 Error Code
Discussion in 'The Workshop' started by Dylann, Aug 27, 2019.
  1. Dylann
    Dylann New Member
    Hi, so I had my mot done today and when i went to start up my sr 50 the clock didn’t come on and it came up with an ‘error 0007’ this has never happened before and the bike was perfectly fine before. The clock doesn’t work at all (doesn’t even light up) indicatiors, horn, brake light, none of dash lights work etc. However the bike started up perfectly fine as it usually does.
    Does anyone know what caused this and how to fix it? Is this the MOT centre’s fault or is it down to a dodgy fuse or something?
    Any help is appreciated, many thanks
    Dylan.
  2. scubabiker
    Hmmm... Is it the ditech version or carb?
  3. Dylann
    Dylann New Member
    carb version
  4. scubabiker
    OK.
    Could well be the wheel sensor.
  5. Lukash
    Lukash Member
    SR125
    Try charging the battery first, had a similar error on NRG clocks and was just low voltage
  6. MARSH
    It's nothing to do with the M.O.T test !
