Hello haven’t posted in here for a few years. Basically have a 2001 aprilia sr125 that has been off the road for a few years was all working fine prior to being put away. I’ve changed the battery turned the ignition and nothing - no power at all the fuel gauge doesn’t even go up. Now I have managed to kick start the bike and it started and runs ok although indicators etc just stay on as it’s not getting enough power. Any ideas where to look? I’ve checked the 2 fuses and they are fine. Thanks in advance Rhys
Could be a dead battery as you said its been sat for a few years. Edit just re-read your post about already changed the battery aha. My bad. Have you checked all connectors ect ?
Lol no problem. No I haven’t yet mate I’m going to take all the fairings off and look over everything I’m thinking possible bad earth or something but it’s been in a dry garage
Do you mean changed or charged battery? If changed then is it the same spec? I would start by running a volt meter across the fuse box connections. Should be no reading until you turn the ignition switch. If nothing then check the earth connections and then bypass the ignition and see if that works.
