Aprilia sr, whats next?
Discussion in 'Scooter Tuning' started by Hackett Sr, Jun 28, 2011.
  1. Hackett Sr
    Hackett Sr Member
    Hi, Iv got a 2009 Aprilia sr50 with the following:
    Doppler s7r 70cc kit
    Doppler s3r exhaust
    Polini kevlar belt
    Polini 9 roller variator
    Pm racing clutch
    Stage 6 primary gear up
    Polini carbon reeds
    What could i add or change to increase power? im open to any suggestions.. (within reason)
  2. Cjkt
    Cjkt Member
    Aerox
    What size carb have you got on there
  3. Hackett Sr
    Hackett Sr Member
    Got the standard 17.5mm, was thinking about upgrading but not sure what difference it'll make
  4. Gamble
    Gamble Member
    You'll see a great difference from a 17.5 to a 21mm. Would definitely recommend that as a next step. :good:
  5. Hackett Sr
    Hackett Sr Member
    Okay then i'll get one, is there anything in my current setup that isnt particually great?
  6. MiNoR cOnFuSiOn
    the aprilia
    adding a crank and doing the cases at the same time would give you a serious hike in power wihtout really loosing any power. common practice in europe/among tuners is to fit a crank and flow the cases when fitting ANY cylinder kit
