i got stage 6 70bore, standard 17.5 carb , malossi variator , stage 6 belt malossi clutch , leovice de restricted pipe, im an really struggling to set it up, i got the box of jets and rollers , it just needs someone that knows what is he doing , i live in west london , got a wan so can go up to you or something like this , if you can do it? got some time and need extra money? email me : mbk3dga@gmail.com
what you struggling with mate????????? have you actually tried owt yet? it's not rocket science... it's a suck it and see job.... your'e a bit far from me or i'd av done it for nowt.
well i got everything together it , it used to start for a second or two and then cut out, so i bought a new fuel tap, fitted it and it dont start now at all, im running 82 jet now , also tried 72 same thing , my spark plug is brand new but its a bit oily so i cleaned it, it gives spark etc, when i get some petrol in cylinder it dont help, i run premix, 20ml to 1l of petrol , any advice of what can i do ? ? will the garage charge me a lot to fix it ? as im good at mechanics etc and got few other bikes done they used to work fine but this one just dont wana work
20:1 ? Seems a lot. I run 33:1. You will find it will be abit smokey till it's started running in ( all the oil in the cases from fitting) are you using a open filter ? Starting jet is ? you want 5-10% for 70's 10-15% for exhaust so a 50 would be 70 ish.
what do you mean a lot? i just dont get that proportion do you put a 33 ml in 1 liter? and the jet is 82 now, ill try a 70 tomorrow , and no im using a box but a gilera dna one (small one ) with a malossi filter inside , thanks a lot for replies
yeah i'm running 33ml to 1 litre of fuel. seems to much oil 20:1. and oh right. buy a box of jets... 82-70 is a big jump.
i dont run 20:1 ! i run 20ml to 1 liter, and i got 2 boxes of jets 50-90 , i tried a 70 jet today - no progress , it looks like its a very weak spark so ill try to get a new spark plug tomorrow maybe
I mean too little -_- argh confussed ! lol. Bassicly 20:1 is too low. You should be running 33:1 roughly.
oh ok lol , but it should start any way and it dont i ordered the spark plug so ill se how it goes then
i dont get it... 50:1 ratio for ONE liter is 20ml. the ratio doesnt mean 20:1 (20ml for 1 liter of petrol)
yeah ure right, that is it. but the ratio doesnt mean how the measurement of oil to petrol. asin 33:1 doesnt mean 33ml of oil to a liter of petrol. if ur ratio was 20:1 and youre measuring for one liter, then it would be 50 ml of oil per liter
