Hey i have a aprilia rx 1999, and the clutch needs adjusting...i've adjusted it as much as i can up on the handle bars but it now needs adjusting down in the engine. How do i go about adjusting this? and which side is the adjustment on? ...same side as the clutch plates? ...right hand side by foot brake leaver thanks
havent had a rx 50 but on my cr125 its on left side (gear selector side) if its cable there should be a nut on the end of the wire before it goes in to the casing adjust this as if to make it tighter (clockwise) but first make the one on the leaver a bit slacker seem as you got it as far as it can go
