Hi all back again got a 2010 rs 50 new shape but carbs seems to be off the mark 1 issue I got revs up to full throttle the minute you start it I thought air leak so replaced inlet rubber and manifold gasket Cleaned carb airlined the jets Replaced all hose clips put all back together same thing happened ? Picture of carb just to verify I'm right with hoses Blue lines water feeds Red line oil feed Yellow line breather? If I put my finger over yellow line breather? Won't start at all But if start without finger over yellow line breather?it starts but revs up to full throttle But if I put my finger over yellow line breather? Slightly I can control the revs? Any ideas
Just pulled carb off manifold this is where the slide is sitting Not closed taken idle screw out didn't even move Checked cable adjuster nothing Needle to low? Not the best of pic sorry
Thanks for reply checked already had throttle off about ten times Had slide out of carb ten times to make sure it was in properly Cables not bent or kink anywhere choke side or throttle gonna move needle tomorrow C if it make any difference
Tried that makes no difference at all Only way I can make it idle is by putting my finger slightly over the hole marked with yellow line in first picture
Take the cable off the carb slide, take the idle screw all the way out, if the carb slide drops fully closed then the throttle cable is marginally too short. There may be an adjuster in the throttle cable about half way along, maybe...... Another thing, the swan neck into the top of the black cap can be screwed in and out quite a bit, but that carb slide should be fully closed with the idle screw taken out.
Oh yeah, they have a cable to the oil pump too. Ive seen one of those splitter bits jammed open before, like the cable pulled out of it if that makes sense?
Thanks for reply Took cable of the slide and idle screw back out gave the slide barrel a slight rub with wet/dry Check splitter where cables meet nothing still sitting in same position as picture So my thinking now is definitely needle have to check tonight after work
Sorry for late reply working late had no time for bike till today Yep bent needle all sorted Thanks for replys Got another issue now started new post Thanks once again
